Re: Visiting the interior of Iceland with a Kangoo 4x4 (TTT-Technik, Tipps und Tricks)
Ron, (vor 8384 Tagen) @ Martin
Als Antwort auf: Re: Visiting the interior of Iceland with a Kangoo 4x4 von Martin am 06. Oktober 2002 19:14:43:
x1/11077.htm
Hi Martin,
Do you know whether it is possible to increase the tire size from 185/65/15 to 205/70/15. This change will increase the floor-ground distance by 2 cm. Is there an option to place the engine air inlet at a higher position.
best regards,
Ron.
Hi Ron,
after 15 jears riding Toyota Landcruiser heavy duty series and several trips with expeditional caracter for example iceland I own an Kangoo 4X4 for one week now. The reasons for change were the better daily use and economy. But especially for riding in Icelands backcountry I would never go there with an Kangoo in spite of you have often to cross a river and 80 cm deeph and more is quite normal. If you look at the costs of shipping, I would rent an fourwheeler with low range gear and a little bit more stability as our Kangoo is. For one time I rent an Subaru Legacy at Iceland but the limits were shown very soon. An area to test 4X4 vehicles for Icelandic qualitys is in the near of Udine/North Italy. I`ll go there at the end of october. If there are interests you can contact me.
Greeting from Bavaria by an new happy 4X4 dci owner
Martin
x1/11077.htm
