Re: autobild 4x4 test (TTT-Technik, Tipps und Tricks)
Dr. Frank, (vor 8358 Tagen) @ Ron
Als Antwort auf: Re: 4 Allrad Wagen im Test: Sieger..na wer schon! von Ron am 01. November 2002 16:41:05:
x1/11973.htm
Hello Ron,
nether mind, our "Nederlands" is not as good, neither.
Renate found this issue, so let me answer you.
Perhaps you'll find the result one month later on www.autobild.de => Test und Technik (on the left) => Allrad. Actually, there's also a test about the 1,9dci.
Back on the homepage there's a very small yellowish button top/middle "allesallrad", where you can see the cover of this issue, but nothing more.
So let me summarize briefly.
model ranking:
Renault - 290 points
+ lot of space for people and things
+ good comfort (suspension)
+ sufficient security features
+ best ground clearance in test
- biggest turning circle
- worst power on steep ascents
- midget pull load
- low seat position (rem: that's relative, compared to height of car)
Mitsubishi - 268 points
+ seats are quite good
+ good trip perfomance
+ good brake perfomance
+ quite good pull performance
- insurance quite high ("VollKasko";)
- high fuel consumption
- very few space for knees of passengers on rear seats
- bad ground clearance
Daihatsu - 236 points
+ lowest fuel consumption
+ cheap insurance
+ small tuning circle
+ just even useable size of interior
- instable behaviour in curves (rem: yep: Kangoo has been turned out to be very stable in curves surprisingly, despite his height. )
- brakes
- off road usage
- noisy driving
Suzuki - 222 points
+ best price
+ best offroader in test
+ very low cost
- unsufficient brakes
- unstable in curves
- hardly any comfort
- very few interior space
Kangoo wins by low costs, because of the advantages of his box-like appearance (i.e space, space, space), ground clearance and his variable slip regulation (100:0 => 50:50)
Rem: the author was definitely no Kangoo fan, starting the article by:
"Bad news first: All four 4x4 won't go as status symbols. For this purpose, they are too small, and much too reasonable choices, as to be taken for a noble toy. All ahead the french Kangoo having a super practical box appearance, which exceeds itself from common beauty conceptions totally."
Well, I hope that's sufficient for first instance ;-)
Frank & Renate
x1/11973.htm
